Hello my GS MK 2 alarm keeps going of every 30-40 minutes. Is this a common problem if so what could it be. Any help be appreciated.
Windy day, something moving inside, water ingress?
Have you tried - assuming there is one - setting the alarm with movement detection OFF?
Maybe check what the manual says?
A window not fully closed?
A moth, fly etc trapped inside ?
A new car parked nearby ?
Kids have new electronic toy ?
Electrical interference?
Does your remote work ok?
Piers--has your own problem been solved yet ?
On 7/19/2020 at 12:27 PM, 39buss said:
Cheers for the replies. I think I might have solved the issue. There was metal/coins in the centre arm rest. Emptied crap out it seems to be good at the moment. There a subsonic sensor under the centre arm rest anything metal causes the sensor to go off. I keep posted if it doesn't work.
