Where can buy Lexus whole screen Wash fluid ?
Many thanks
I would imagine the only place would be Lexus dealers, but you do know that Lexus don't make the fluid, don't you?
All they'll do is buy it in from Fred's Screenwash Company, rebadge it and charge you three times as much as Fred would.
It's branded as Toyota, so either dealer will have it, or order off the 'net.
Can I use the Michelin
Looks good to me.
I like to buy the concentrated and dilute to requirements.   I Increase the strength as it gets colder and take the opportunity to give the wiper blades a rub over with it at the same time.  Be aware though that an overstrong mix can tend to block the jets.  Radiator coolant is of couse totally different and it is important that Lexus recommended fluid be used if needed.
My old 2001 BMW has two systems, one for normal use and the other for a more intensive wash so I use the same stuff for the latter but at greater strenght but I don't think Lexus have achieved that level of sophistigation yet!
