3 minutes ago, Tel said:
I have got a 6 inch USB cable to facilitate my connection ( when installed) & when using ACP your phone battery will be charged.
You cannot avoid plugging-in your phone.
Tel
In the online instructions, it says you "must use a data certified cable" not just a charging cable.  Not really sure what that means - I use an original apple cable and it works, but if you have issues with other cables, that may be why.
Using a certified apple cable (Belkin).
Tel
Tel
Here's an option, but I'm not sure whether anyone would consider it reasonably priced: https://cplay2air.com/
When using ACP does Siri announce that you are approaching a fixed speed camera & prompt you to slow down if your approach is too fast ?
Tel
Please answer the above as this issue is key to what is the best Nav system available IMHO.
Tel
I have it. Works really well. Not exactly cheap though.
Phil,
Does ACP retro fitted by Dealers announce Speed Cameras via Siri please.
Terry
Tel
Cameras are on the maps, yes.  Whether they warn you, like Waze, depends on if you have settings for warning turned on
Speaking of speed camera warnings, is there any way to turn the volume of speed camera notifications up on the normal nav?
Oooh - might get that.  Since I got my ACP upgrade for free it feels worth it....
Love this man's math. I'd get one immediately if one was available for Android.
Sent from my SM-N960F using Tapatalk
Tom
No
Raised with the experts @ Lexus UK as they are definitely too Quiet
Paul,
I will ensure when they install they set the warning to ON as SIRI informing you is the best warning as 'He" mutes the radio in our Aygo.
1 hour ago, Tel said:
Tom
No
Paul,
Hi Tel, apologies if this is a dumb question but what do you mean about setting the warning to on? Where is that done and can it only be done during installation?
I'm getting ACP installed on Friday. I reckon I'll be buying it shortly after. I can't really justify the cost, but so what. 😁
Post above by Paul infers a setting is available in the ACP Menu
Tel
HI Paul, where exactly does one turn the warnings on in settings?
Cheers for your help... 🙂
My Lexus Nav is perfect because of the HUD but Speed Camera Dongs are very Quiet.
My Factory fitted Aygo ACP is perfect (except for the lack of a HUD) & Siri announces 30 MPH Speed Camera ahead etc.) Siri guidance is more frequent than Lexus & mutes the radio.
IF the Lexus After Market ACP is per the Aygo I will go ahead with the installation next week but if it is not I will not bother & assume my next Lexus with Factory-fitted ACP & HUD will be Perfect.
I drive regularly to Italy & hope to return one day.
Please Advise.
Terry
So I got the AA upgraded by Lexus last week. Not had a chance to properly play with with it, however it seems to be working OK - Google Maps and Waze seem to be working.
Not so good things:
1) AA automatic start when phone is connected - not sure if this can be done... first time using AA in any car
2) Disconnecting AA - the MM unit returns to full screen rather than what it was before (Split screen)
If I figure out the above, and if it can be done, I'll put a post up on here
Not so good things:
Hi @villieb
With regards to your point 1 above, I have found that the best way to get AA to auto-start is to connect the phone to the car's USB port before starting the car. Also ensure that "Android Auto" has been selected as the "Preferred service" in the head-unit's settings (under "General" IIRC).
I do find that the system tends to deploy the last-used display option (AA or Lexus display) when starting up again, but as I use AA pretty much exclusively now it's not a problem for me.
Car Play up-date done & works perfectly with the HUD showing my speed & the Speed Limit of the Road
Siri announces all Fixed Speed Cameras & ,pleasingly, does not Mute the Radio,when giving Directions.
The Courtesy Car was a new RX that I did not have to pay for & the cost was £80 including VAT. Took 4 hrs including the Safety Check & Shampoo & Set inside & out.
Chuffed.
Tel
Siri now "lives" in the dash so it erases the need for the Lexus Call Button that caused many people frustration.
Tel
What does this aforementioned Device give you over & above my System please?
Tel
