Hi all,
I've been struggling with leaks in my RX400h for some time now and I finally gave up with the self-diagnostics and took it to a leak specialist based in Chelmsford. That's all they do pretty much - fix leaks. I had leaks coming into the boot, down the C pillar in two different places and obviously pooled water was making the rear (and even front) mats wet. By the end of a week of repairs followed by testing, again and again, they found all the leaks - tail light seals, boot seal, roof rails, door cards and a few others. The process is amazing - they run cams into the car, smoke, foam and all sorts and then show you videos of the leaks. The door cards were a real shocker - basically any rain hitting the windows was working it's way onto the wrong side of the door and then (mostly onto the sill and out, but still..
So, I had new door cards made up, all the leaks sealed up and whilst I was at it, the headlights re-polished and re-coated, new number plates, all the stone chips patched up, alloys sorted and finally a clay bar and nano coating..... the car honestly looks brand new now.
I waited a month before posting this up to wait for some real rain and use, but it's all good, not a single leak into the bootspace or anywhere else!
  • Like 5
38 minutes ago, 06_400_h_se said:
Hi all,
Happy days!
Good news.
Who did you use?
8 minutes ago, PCM said:
Happy days!
Good news.
Who did you use?
Very pleased for you Lex. Can you indicate their leak seeking charges please ?
Hi - are we allowed to post company names on here? If so, the firm was New Again in Chelmsford. Roy, I started with the 28-point check which was £125 and then you basically decide where you want to go from there. It's mainly labour charges that you are paying for and obviously each car will be different. I had so many leaks that it took a long time to identify, rectify and wait for re-testing. I already had in my mind that I plan to keep this car for another 5 years, so I figured I'd get everything done properly, including cosmetics. Labour charges seem to come in around £45/hour on my invoice. Here are some pics of just one of the worst leaks before I took it in as it was starting to get quite silly.
I had that one. Did all sorts and finally cured it but was never quite sure which fix or combination of fixes did it!
Many thanks Lex. Considering your intention to keep for a good while you have indeed made a sensible, cost effective  and worthwhile investment.
As far as naming Companies is concerned ,my view is that one should be truthful whilst not being libelous and to declare an interest where necessary. Never criticise an Organisation without first having tried to resolve the matter with the organisation. And never invoke L.O.C. in any matter.
Looks like money well spent and makes you feel completely different about your car.  Worth making a note of anybody that can do this work especially as labour rates well below those of Lexus dealerships.
