My RX400H passenger side power mirror folds in while making a loud clicking noise , then won’t unfold. I’m happy to strip it down but any ideas what I’m looking for ? Thanks
Could be the teeth on the clog or wheel are worn,and therefore causing the clicking noise,try spraying the inside of the mirror with some wd40 and see if this helps
As above but I would use a dry PTFE lube spray (as used on MTB chains) WD40 is rather thin, more a water dispersant. Either way, looks like a strip-down required.
Can I strip this from the outside without taking the whole unit off the car . I did consider buying a second hand unit and swapping the parts reusing my case which is in good condition.
