Hey everyone I’m new to Lexus owners
Bought first ever Lexus is250 and it has VSC light on
checked with scanner no code comes up
please suggest solution
thanks in advance
Did you have ignition on when testing? If so very strange, was there any stored codes.I have always been able to read Vsc codes, even with a cheap scan tool.
Disconnect Battery ( Negative - connection ) for tens minutes to do a soft reset of the volitile memerory in the ECU's if there is a 'real' problem somewhere with the car then the "VSC" will pop back up but for a no cost first action just in case it's a spurious code then it's got to be worth a try!
I had a vsc light come up once after I didn't tighten the fuel cap enough. Went off as soon I took off the cap and retightened it till it clicked.
