Hi to you all again......What amount of antifreeze do I need for my Lexus LS400 1995 and will Red Concentrate antifreeze be ok....Thank you Roy.
Yep, 5 litres Toyota red concentrate and the same in distilled water, if you have a dehumidifier use the water from that.
Don’t forget to drain the block via the drain cocks.
Or Rainwater ( plenty of that around here at the moment!), sieved through a cloth or coffee filter!
