4 hours ago, royoftherovers said:
Any link Phil ?
2 minutes ago, Bluesman said:
Well spotted.
5 hours ago, The-Acre said:
Another LS430, he seems to like them!
can you please remind us all once again of his legendary names  ?
I wonder where the Mark X ended up?
Back to his usual choice of Lexus again now with a comprehensive 3 month warranty ( covering engine and transmission only) probably subject to as many Ts & Cs you can write on the back of a used cigarette packet and worth about the same.
The “Small blemish” on the rear bumper that looks more like “the old boy” reversed into a brick wall before hanging up his licence.
”Indeed” another one to avoid.
passenger side looks entirely different to the Drivers side - or is that my imagination/the light??
When is a crease not a crease?
Looks nice - not checked MOT history - could this be the sound one?
Stu--can you provide a link please as I`m floundering ?
try under LPG 06 L****  Guess we all have to be so careful these day.  Don't want to upset anyone for fear of being a radicalist- ha ha ha.  If only it was funny!
4 minutes ago, royoftherovers said:
Many thanks Steve. Now if Phil had provided the link...................................................!
Indeed.
Quite a big, 'blemish', at the back.
He is ignoring his Statutory Obligations again, I see. "Caveat Emptor."
Cant get any details on its MOT history, keeps saying wrong details.
Update in the above managed to get the MOT details and its record  is very good.
Still be very careful definitely "Caveat Emptor"
Date tested23 October 2019
PASS
 View test certificate
Mileage151,602 miles
MOT test number5429 1427 1287
Test location
 View test location
Expiry date23 October 2020
MOT history
Check mileage recorded at test, MOT expiry date, defects and advisories, and view test certificate
PASS
Test location
 View test location
Date tested17 October 2019
FAIL
Mileage151,575 miles
MOT test number5698 9714 6399
Test location
 View test location
Repair immediately (major defects):
  • Nearside Front Tyre not fitted in accordance with side wall instructions (5.2.3 (i))
  • Nearside Front Brake hose excessively twisted (1.1.12 (b) (ii))
Monitor and repair if necessary (advisories):
  • Nearside Front Tyre has a cut but not deep enough to reach the ply or cords (5.2.3 (d) (i))
 What are defects and advisories?
Date tested24 October 2018
PASS
Mileage150,061 miles
MOT test number8630 1634 0524
Test location
 View test location
Expiry date23 October 2019
Repair as soon as possible (minor defects):
  • Tyre pressure monitoring system warning lamp indicates a fault (5.2.3 (h) (i))
  • all 4 tyres wearing on edges
 What are advisories?
The MOT test changed on 20 May 2018
Defects are now categorised according to their severity – dangerous, major, and minor. Find out more
Date tested18 October 2017
PASS
Mileage147,443 miles
MOT test number9284 4844 1055
Test location
 View test location
Expiry date17 October 2018
Advisory notice item(s)
  • all brake pads wearing thin
  • corrosion to inner sills
Date tested22 August 2016
PASS
Mileage142,142 miles
MOT test number7701 8656 5119
Test location
 View test location
Expiry date23 August 2017
  • light corrosion to sills
Date tested24 August 2015
PASS
Mileage139,002 miles
MOT test number1026 7760 2861
Test location
 View test location
Expiry date23 August 2016
Date tested1 August 2014
PASS
Mileage133,223 miles
MOT test number6776 5371 4271
Test location
 View test location
Expiry date16 August 2015
  • Under-trays fitted obscuring some underside components
  • Engine covers fitted obscuring some components in the engine bay
Date tested15 August 2013
PASS
Mileage129,887 miles
MOT test number1256 8752 3225
Test location
 View test location
Expiry date16 August 2014
Date tested17 August 2012
PASS
Mileage119,336 miles
MOT test number4950 9033 2232
Test location
 View test location
Expiry date16 August 2013
  • Front Brake pad(s) wearing thin (3.5.1g)
  • Rear Brake pad(s) wearing thin (3.5.1g)
Date tested29 July 2011
PASS
Mileage107,092 miles
MOT test number8755 2021 1234
Test location
 View test location
Expiry date1 August 2012
  • Nearside Windscreen has damage to an area less than a 40mm circle outside zone 'A' (8.3.1d)
Date tested2 August 2010
PASS
Mileage90,973 miles
MOT test number4214 1481 0261
Test location
 View test location
Expiry date1 August 2011
Date tested30 July 2009
PASS
Mileage68,498 miles
MOT test number2244 1111 9209
Test location
 View test location
Expiry date31 July 2010
FAIL
Mileage68,498 miles
MOT test number2639 5191 9274
Test location
 View test location
Reason(s) for failure
  • Offside Front Front position lamp(s) not working (1.1.A.3b)
 What are failures and advisories?
Outstanding vehicle recalls
Check if LEXUS LS430 MD06VPE has outstanding recalls
Support links
Open Government Licence
All content is available under the Open Government Licence v3.0, except where otherwise stated
Well unfortunately Phil can't work out how to post the links, probably because he left school at 15!
Apart from Lexuchap, lexusbloke and jaguarbloke, his latest one is funinthesun with various dots and dashes in-between.
Try Googling the question Phil.
If I Googled everything I may as well donate my brain to science, I'd have no further use for it.
And if I had looked everything up in Encyclopedia Britannica, I would have learned a lot !
The inclusion of an appropriate link is often rather useful. Next time I am down your way Phil, I will show you how.
Don't bother, I'll ask one of my neighbours small children!
yes, up to age 11 is about the max age to get a sensible hitech outcome these days
Just as long as you don't mind the word "like" 6 times in every sentence!
