Is there an easy way to check which version of satnav is in my 2008 RX400H?  I cannot get the DVD to eject from the player in the boot of the car so wondered if there is any way I can check using the display in the car?
I don't know the answer to your question but if it's old and you want to update then you'll have to get it out anyway, so I'd keep trying with that.
Hi, are you aware the ignition has to be switched on when trying to get the disc to eject?
