Can anyone tell me if is250 coil over shocks are a straight forward fit on a 2008 is220d the person selling them obviously says they are can somebody confirm this please. Many thanks in advance.
The originals have different spring/shocks part code due to supporting different weights between the models but they physically are the same. Adjustable Coilovers will fit both petrol and diesel.
  • 7 months later...
Yea you can fit them I bought the is250 BC kit but later called BC and order 14kg springs for the front as I run very low! If you don't run silly low the standard is250 kit (10kg/12kg) are fine
