Good afternoon all.
I hope someone can help?
I have had a look through the forum but could not find the answer to my question - Sorry if it is there...😇
So over the lockdown my Battery kept dying and I charged it using a AGM compatible charger.
Now that I am back at work and driving it normally i find that the Battery goes flat every couple of days so definitely time to change the Battery.
I have found a Battery but.... Does this vehicle have a Battery Management System that needs to be reset by a main dealer or is it effectively plug and play?
Many thanks in advance! 😍😍
Roddy
Thank you Inazone for you reply, much appreciated.
