Is250 failed mot. Halfrauds.
Need advise. Should they replace one end or should I ask them to do both? They are charging 130 for the track rod.
Did they advise both or just the one?what does your mot/reason for failure actually say?
Just one. Said that the cover for the trackrod joint is damaged so it is mot fail.
If its damaged then have just the damaged one done,although if you have the money you could do both,but not necessary at this point in time
So they came back and said it isn't track rod. It is ball joint that holds the hub and they replaced the cover only. Charged near 80 pounds for it.
Well at least it's and a worry off your mind 👍
