I'm trying to remember but age has beaten me, can anyone remember if there's a reset for this warning? I'm sure I did it when I had my manual in English rather than Japanese.
Hi Phil
Is'nt that in the procedure for checking the A/C on the touch screen were it runs through the different vent and boost settings and reads them off as it progresses ,I have to confess I have only done it once on the old LCD display Mark 1 but I am sure there is a similar procedure for the touchscreen.
Hi phil
I believe you get this warning when the cabin filter needs changing
To reset press and hold the off button for the climate controls whilst the engine is running
hope this helps
Hi Phil
Just checked google and the procedure is as Mark says on the 460 so I would expect the same procedure for the Celsior.
Much obliged Mark (and the other Phil) Having it all in Japanese makes me nervous in case I press "seat eject"  Talking of imports, I went to a glass cutters today, just before they closed for the foreseeable, and the guy had a Nissan Skyline import, what a tasty car!
