Hi All,
I need some quick advice pleaee
I've noticed my driver's side Headlight flickering every so often.
Its the original Toyota lamp/bulb.
(Front Headlight Xenon bulbs Part No
Lexus D4S Xenon Bulb
Lexus Genuine Part Number: T90981-YZZCC)
The original bulbs are about £70 each and I understand they should be replaced as pairs.
Is the flickering definitely a symptom of a dying bulb or could it be something else?
Is there an argument to replace with original bulbs or could I replace with a cheaper alternative? (any recommendations would be most welcome)
Many thanks in advance.
Nish
Yes the flickering is one of the symptoms of a dying bulb or possibly ballast, personally I change mine in pairs(as soon as one goes the other is not far behind lol).You definitely can get them cheaper or on the other hand pay a lot more depending on brand ,osram,Phillips etc
Nish,
I have one headlamp with low-cost bulb and one with high-cost bulb.
I cannot tell which is which.
John
Try swapping the bulbs over, side to side and see if the flickering moves with it. Would rule out a failing ballast?
