Anyone know how to open up the back of the sun visor? Stupid me, I put a small laminated parking pass in the mirror of the visor on the drivers side for ease of access, then closed the sliding cover! The pass then disappeared into the visor:(
Not life threatening, but would be good to retrieve it.
if your sitting in the drivers seat , on the right hand side edge of the vanity mirror i used my panel removal tool
to release the 2 lugs that hold the mirror frame in place , when you are releasing the clips apply a little
pressure to the mirror pulling it away from the visor it will then unclip, then slide the mirror unit to the right
to remove it.
if i can find the pictures i took i will post them up for you
found the photo, it is showing the right hand end of the drivers mirror
you can clearly see the 2 rectangular holes where the clips locate
if you have to remove the sunvisor
then remove the cover from around the pivot point for the sunvisor
remove the 2 screws
unclip sunvisor from the support clip and then pull sunvisor downwards gently
it will unclip and come out
Thanks Mark, that is so helpful. I do not have a panel removal tool, but as I am self isolating at the moment this will give me something to do:)
Hi Barry
you can use anything flat and blunt to release the clips
it took me a while to find how to release the vanity mirror
so i made sure i kept my photo's
