Our 2012 RX has started squeaky when on uneven ground. Sounds like a pc/abs contact squeak, from within the dash board.
Anyone else experiencing this? Any ideas on how to fix?
I'm thinking of taking some panels of and checking torque on fixings or trying to Isolate the materials if it is pc/abs contact squeak.
Thanks Darren.
Have you checked it's not the glovebox?
I have the same issue, i think its on the bottom of the windscreen
On my rx300 I had a rattle/squeak at the front edge of the dash when the car was cold. I sorted it with some sponge cord pushed into the gap between the dash and the windscreen. It put just enough pressure on the front edge of the dash to stop it moving about.
Sponge cord is what the dealers use to plump up door seals that don't quite fit snug and plug rattly gaps. I'm sure I saw it first on wheeler dealers.
Hi guys, thanks for the replies, I'll check the windscreen, maybe try push spounge down as suggested. Thanks.
  • 7 months later...
Hi all
I have rx300 from 2004 I have 4places where my dash is sticking first is near front window and another where is the dashboard and 3rd where is radio on top where is display
Last one is back passenger seat is giving shaking noise can any one help please
