I have a 2005 GS300 (Phase 3) I had a new TPMS sensor (bought from Lexus) fitted in December, the Check Sytem warning light has come on twice since then. My local garage says that there's no faults with any of the sensors. It appears that when the tyre pressure drops the Check System light comes on instead of the Low Pressure light. They're going to put bead seal on the rims and reset the warning light. Any idea why this is happening?
"Check system" = communication problem between ECU and sensor. Use TechStream to check which sensor is giving this error.
"Low tire" = communication ok, pressure is below the limit.
Did you replace all four sensors, or just one? Could it be another sensor failing this time? Typically they just run out of Battery, and it likely will happen to all of them sooner or later.
BR:Sami
  • 2 months later...
