Hi
I am trying to get a  towbar fitted to my NX300h but having contacted several reputable suppliers / fitters so far none have a towbar to suitable. I have contacted my Lexus dealer and have had a quote for well over £1000 to supply and fit. I expected expensive but not that much!
I intend to pull a caravan so need appropriate electrics and preferably detachable.
Can anyone help.
Any additionals to the tow bar required, such as extra cooling for the transmission etc..?
I’ve got one (detachable) on mine. Never used it, was installed (official Lexus) by previous owner.
  • 1 year later...
On 2/24/2020 at 10:31 PM, JWK said:
Hi
Can anyone help.
Hi John,
I am going through exactly the same problem. None of the major towbar manufacturers do a bar for the NX. Lexus Sheffield have quoted me £1031 for a detachable supply and fit but with 7 pin electrics, obviously 13pin will be slightly more.  They will supply Parts Only for £690 and for me to find some body to fit it but I understand the labour is quite high as they have to dismantle a lot of the car rear. Did find a company on the net in Shropshire, Telford Towbars who were listing the NX supply and fit for around £750 but have been too busy to take it any further. Holpe this helps.
Regards  Clive
1500kg towing capacity for an NX300h AWD. It did quite well in the caravan club towcar awards according to the write up.
Posted (edited)
6 hours ago, Clive M said:
Telford Towbars
Sure enough, Telford Towbars - online quote, removable towbar, fitted at your place (£30 - they must go nationwide?) with VAT £719.99
On line quote (Vehicle reg taken from an ad in Autotrader) Telford Towbar Quote for Lexus NX
Edited by Phil Catterall
typo
Hi Clive
Further to my post above I contacted Towbar Express this morning who fit towbars at customers homes. They fitted a detachable Witter towbar and 7 pin electrics on to my Skoda Octavia Scout 3 years ago at a cost of £402 (Cost now £537!). It was a good job. The firm tell me they will only fit towbars to the Lexus RX model and for the NX they suggest I contact Lexus.
I'm hoping to buy a one year old NX once the lockdown ends and I need a towbar for carrying a bike rack. The Sheffield dealership is a distinct possibility for purchasing as I live in North Yorkshire, however at a cost of over £1000 to get the towbar fitted is making me think that the NX may not the car to go for.  As I ride a normal bike and also an e-bike on occasion, which is much heavier, using a roof mounted rack is not feasible due to the weight.
The jury is out....
Good luck, Phil
I got a tow bar fitted on thursday. Called around to quite a few places and most recommended and installed Steinhof, which seems like the best non-lexus option
Went with Car City Care in north london for the install as they did it for just £500 which was quite a bit lower than the second cheapest. They even managed to keep my under run although they did have to make a cut.
Have yet to tow something with it but all looks like it's working well.
That's excellent at the price Erik. Luckily for me the NX I'm getting in a fotnight had a towbar fitted from new. It was looking like if I had to get one fitted it would have cost me around £1000. The places I enquired at in Yorkshire couldn't source a Lexus towbar it seemed.
All the best
Phil
Worth checking if their is any additional Brexit duty / courier customs clearance costs for UK purchasers if anyone buys from this EU based company. The cost of the towbar is above the £135 import threshold.
Regards
Phil
On 5/16/2021 at 11:56 AM, Las Palmas said:
A hybrid is not really meant for pulling much more load than its own, but if legal and you do not mind the extra fuel and wear on the car:
https://etowbars.com/uk/Towbars/Lexus/NX
Not that expensive.
Lexus rate the towing capacity for an AWD NX at 1500kg. They wouldn’t say this if they weren’t really meant for towing
  • 3 years later...
Hi all
Has anyone actually towed a caravan with the NX?
I'm thinking of going for the NX200T which would more than likely tow better than the Hybrid.
Hi.
I tow a swift Basecamp 2 with MTPLM of 1043kg with my NX300h . No issues whatsoever but fuel economy drops significantly & lots of high revs going uphill. Very capable towing small caravans & I believe is capable of towing up to 1500kg but personally I wouldn’t want to push it that much.
Hi Steve
That's a similar weight to my caravan,
Do you find it difficult to the Vans nose weight below 60KG as that's the limit for the NX towbar?
Hi Tim,
I use a milenco nose weight gauge & actually I struggle to get the nose weight up to 60kg. I carry a safefill gas cylinder weighing 11.6 kg when full in the front locker along with spare wheel & all the usual accessories. I place the awning & associated heavier items over the axel area & store the waste master & aquaroll in the shower / toilet area towards the rear of the caravan. Mostly tow with a nose weight around 50-55kg & no issues so far. Everything else I carry in the car to ensure I don’t exceed the MTPLM. The only challenge I faced was finding someone to supply & fit the detachable tow bar. None of the independents wanted to know & ended up back at my Lexus dealership paying Lexus prices ! Hope this helps 👍
Hi
You balance your Van exactly as I do, I just have to aim for 75kg nose weight that takes a little work.
Telford Towbars can fit a detachable towbar on the NX for about £900, probably a considerable amount less than Lexus.
