Posted (edited)
Just purchased an Nx300h haveing had two other models. I'm using the same mobile. I paired my mobile, no problem. But its draining my android Battery, whether the car is being used or parked on my drive.
The lexus is the only Bluetooth paired device. The phone settings have not been altered from when I had the last lexus (other than pairing)
Streaming media, off
Edited by palcouk
Add item
What Steve says above.
There's no way that your car would have Bluetooth active when the ignition is off.
Well I switched blue tooth off on the phone, then turned it back on, after a reboot. I then rechecked the pairing on the Lexus, and since then all is ok with no serious drain
It might be that the phone got stuck in a cycle of constantly trying to find one of your Lexus connections. A similar thing happens when the phone can't get a signal from the provider's network.
