2 ISF’s spotted
It’s hard to spot one let alone two,
grey 12 plate ISF in Ilford area, always on the drive (like mine) 😂
white 62 plate one at festival leisure park Basildon this evening......parked on the end (again like mine when parking) 🤣
are they becoming common? Lol
4 minutes ago, dman2004 said:
Is the Grey one always front facing the street? Depends where in Ilford! There's a chap on YT with an 08 ISF in the Goodmayes area too.
Always facing the street, from memory it’s a 12 plate ISF
Yeah that's mine - I wouldn't call it Ilford tho 😝. I leave it front facing so people can't really tell what it is as the exhausts are a dead giveaway.
Are you local?
Are you local?
I’m in wickford BUT work out of Hainault depot on the underground, pass your car most days, tbh I’m not a lover of exact location being revealed where cars are concerned 😉......totally understand drive position too, she does look good ☺️
Train Driver? Me too, but Driver Manager now in Crewe. 😁
 Haha Touche! That's quite a distance though, just looked at the map.
 Just had the back boxes removed on the car and now sounds like a V8 should albeit a little drone at 2k rpm. I see the wax is holding up fine too 😉
I had a cat back SS system fitted last year with resonator removal, does make a huge difference, unleashes the engine note 👌🏻
I do the exact same thing!
