I was under the impression for some reason that I could check the tyre pressures of my ES using the onboard display.  All I can see in the settings menu is TPWS  and the option to reset it but no actual pictorial display showing each tyre pressure.     Did I just imagine my car has it or was it my GS or LS that had that function or possibly is it Takumi spec only.  Any ideas ??
With the GS it was specific to the premier grade so maybe takumi only on ES.
You need to be in the left hand page on the TFT screen, once there scroll up or down to see the tire (sic) pressure readouts.  It’s not in the general settings.
I’d be very surprised if it’s a Takumi only thing.
Thanks Pete,  I get it,  I'd forgotten that you can scroll up and down in the  "i"  information read out.  I have left the  power direction display on for so long I forgot you could scroll up and down.
Many thanks
Steve
For completeness, base model here, I can see the tyre pressure as described.
