does anyone know where to get coil springs for the rear not lexus as they want £200, 2010 rx450h, had the right one under warranty 2 years ago now left one has failed, no warranty
Unfortunately they are dealer supply only.
One of mine has just snapped on a 2011 RX450h. Unfortunately the bottom bolt has also seized (carrier to hub) and they will need to cut it off.
The bolt has taken nearly 3 weeks to come but they have also had to order a replacement hub as if it damages the bush the bolt goes through this is not a separate item but attached to the hub, meaning nearly £800 in parts alone rather then just a spring and bush.
If anyone has an RX450h especially an older one I would advise you check these lower bolts to make sure they are not seized and if they are not then keep them greased or replace them asap.
Lexus part no is 48231-48581, if you or anyone else manages to find them cheaper elsewhere please let us know.
Well managed to sort it with a second hand spring from eBay off a 2013 model for £13.50 delivered from Lithuania, took an hour to replace it. 3 bolts to take off, push the carrier down, spring out and in and bolts back on no problems.
  • 3 years later...
Posted (edited)
Did the 2013 spring fit the 2010 model ok?
Edited by energyman
mispelling
