Taking advantage of not having to work at the moment. First job I tacked was to change the diff oil. No idea when it was last done (if ever). But I think you can have a good guess based on the colour.
I was going to be changing out the ATF but the fill plug is buried so deep in the tunnel I can't get a socket on it and I have no 24mm spanners. I've ordered one and will have to wait until that arrives.
In other news, I hate this brake disc. The car is currently still on jack stands because this refuses to come off.
I've ordered a brake disc puller (which was not cheap) and a big ole' hammer (which was). Hopefully I can get this off with a bigger hammer then the one I have so I don't have to fork out money on this puller. Cross your fingers for me, because after all that hammering I can't cross mine anymore.
Wow, I've never seen one so firmly stuck.  I guess you tried some heat?
Heat, WD40, hammers, chisels, swearing, more WD40, crowbar, more hammering, swearing again. I swear somebody welded this thing onto the hub.
You have I assume tried putting 2 high tensile bolts in the threaded holes and gradually and evenly tightening them onto the hub face?
Yep. One stripped the threads out, the other broke a piece of the disc off. You can see that on the left hand side of the disc.
35 minutes ago, Herbie said:
I find this stuff to be infinitely better than WD40 for releasing stuff.
I actually ordered some PB Blaster already. Usually only sold in the US but I found a UK seller, should be here tomorrow. It's supposed to eat through the rust. Never tried it so lets see if it works. Either way I've ordered a 14lb sledge hammer and a brace disc puller - that's going to be my last resort as it was quite expensive. Hopefully I can hammer it out and return the puller. Doubt I'll ever need it again.
Haven't been able to listen to music in the car as the rear sub was blown. Ordered a new surround replacement kit from the US.
Bad news is, once I removed the sub I tried to stereo to see how it sounds and it's still distorted. Looks like the drivers side speaker has the same issue also. I've ordered another repair kit but it has to come from the US so they'll be a wait on that.
I must say Andy you are a revelation, willing to get stuck in to anything, with brilliant reports, which are both entertaining and informative, well done, Rgds, Roger
Well thank you very much 😀Yesterday was my last day of working due to redundancy, and with the lockdown I have to keep myself busy somehow otherwise I'll go stir crazy!
At least there aren't restrictions on car fettling if we have space to do it away from people.
I'm going to be sore tomorrow, even with a massive sledge hammer it took some beating.
Looking much better now.
You can see how much rust is on the back of these.
I'm guessing I loosened up the other one because that came off with a few whacks with the hammer. But the passenger side took a good 5 or 10 minutes if smacking it, and this was no small sledge hammer.
On another note, when I bought the car I noticed two of the tyres were leaking. Pretty annoying as I have to top them up for each journey. Thinking it was a puncture I treated the car to a nice set of Goodyear Eagle F1s but unfortunately it's still doing it. I sprayed them with soapy water and it looks like they're leaking from the rim.
IMG_1785.thumb.jpg.fe959dd1a18c39d4481c17f6c568ba03.jpgIMG_1786.thumb.jpg.0ec66acd35dfc9889b110bafea71599a.jpg
Do you think this could just be corrosion that can be cleaned up or am I looking at a new set of wheels?
I was going to change out the ATF but I couldn't get the fill plug loose. It's a 24mm bolt but there's not enough room to get a socket in there. I bought an offset spanner like this, but it just slips off the bolt:
1745244361_Screenshot2020-03-31at18_28_50.thumb.png.05898dd9d44a17911a5961725b3020f8.png
Does anybody know where I can get a similar spanner that's a 6 point instead of a 12 or whatever this one is?
Another thing I've always wondered, any idea why the car goes all gangsta lean after it's been lifted off the ground for a while? My old one did it too. Are my struts leaking or is this just something they do? (It never does it on the ground, even when left parked).
Tyres are now all fixed. One of them actually had a crack in it which was causing it to leak. The other just had dirt around the valve that needed cleaning. Luckily I had an old set of wheels from my last LS so we just replaced the cracked one with one of those.
It seems these Lexus wheels have a problem with cracking. I had a wheel on my last one get cracks along every spoke.
Another member had a really badly cracked wheel recently, I've not heard of it being a common thing though.  I don't know why the car would sag after being jacked up but the sir struts are complex beasts,  it may well be because the height sensors have been raised so high.  Glad you got that disc off at last, did you dance on its grave?!
I think that was andy when he had the silver LS
So just me then 😆
I didn't have the strength left to dance! I'm sure all the neighbours wondered what on earth I was doing smacking my own car with a sledgehammer though. Probably thought I went made under lockdown conditions haha.
I see....
So I came outside yesterday to find both tyres completely flat again, even on the one where I provided a replacement wheel I know to be good. So I had to have somebody come out for a third time to take a look. It appears there was corrosion as suspected, especially on the one we didn't replace. It appeared no effort was taken to try and remove it on any of the other visits. The paint was pealing and flaking right off, there's no way a tyre would have made a good seal on that surface. The guy that came today actually took photos to report it to the other guy's manager as obviously this wasn't acceptable. I was using tyresonthedrive.com. I've used them for years and never before had any issue like this with them, I recommend them to everyone.
Instead of trying to clean it up I just handed him over another spare rim I had which was much cleaner. He cleaned them both up and added some sealant. The replacement does have a slight buckle but nothing that can't be evened out with some weights. Hopefully when I go outside tomorrow I'll find they're still holding air. I don't fancy buying a new set of wheels at the moment. If I do buy a new set of wheels they won't be Lexus. I've had nothing but trouble with these wheels and I've had 3 sets of them. Two of the tyre fitters I spoke to told me Lexus wheels were not great. Surprising seeing how everything else on the car is so well made.
In other news, I've had to get in touch with the company that built my exhaust for my last LS. I have it and want to fit it to my new one, but I can't use stock gaskets because they cut off the original flange on the cats and welded new ones on. I guess they did this so it would fit the flanges they have for the exhaust side, rather then trying to make ones that match up to the cats or use the old rusty flanges from the original exhaust.
Also took advantage of the weather and treated it to some snow foam.
I cleaned up the manky floor mats with the jet washer too. They came up looking much better then before. Hopefully they won't take too long to dry out. Tomorrow I think I'll finish off cleaning it, and wire up my dashcam and GROM-USB3 which I've been putting off for too long.
47 minutes ago, The-Acre said:
And don't forget to mow the lawn!
It's on today's list, I did the front yesterday. I'm trying to space out my chores 🤣
Don’t tell him that Phil....will stop our entertainment 😂😂😂
Ditto!  And I've just washed my car to discover paint splashes on it from painting my garden workshop, another job to pass time!😁
Oh no, have you tried using a clay bar? Hopefully that will work and you won't have to resort to something a bit more harsh.
Or just finish the job and respray the entire car using the same paint 😂
Good idea but I'm not sure a water based "willow" will suit!  At least I waxed it recently so it could be worse. I was thinking the same about a clay bar and as I have one that's what I'll do.
It'll take some elbow grease but at least it won't be too harsh on the paint. If that doesn't work (I'm assuming this is water based paint?) - if so you could try using acetone (or nail polish remover which is just a weaker acetone). Just make sure to wash it off immediately as it will start to eat into paint, but in my experience contact over short periods of times doesn't do any damage.
