Anyone have a pinout for the sppedo cluster for 09 lexus is250? I need to power up a cluster thats not in the vehicle to see the mileage on cluster?
thanks for help with my first post.
Mack
  • 5 months later...
Just saw this now. Not sure if you are still looking for the pinout but thought i'd reply.
I've done some extensive work on the speedo and a lot of reverse engineering as i'm currently swapping out my second gen cluster with the LFA style 3rd gen cluster. Diagram and pinout of the 2nd gen cluster below. Hope it helps.
J34:
1 - Ground (E2)
2 - Fuel Level Sending Unit Ground (FE)
4 - Tire Pressure Set A/B Selection Output (INT)
5 - Speed Signal Output (+S)
6 - Multiplex Communication Line (MPX+)
8 - Illumination Dimmer Switch Max Bright Input (TC)
9 - Illumination Dimmer Switch 5V Supply Output (ILL+)
11 - LH Turn Signal Indicator Input (B)
12 - Power Supply from GAUGE Fuse (IG+)
13 - Ground (Signal Ground, ES)
14 - Illumination Dimmer Switch Ground (ET)
15 - Tire Pressure Initial Switch Signal Output (INT)
16 - Engine RPM Signal Input (S)
17 - Speed Signal Input (SI)
18 - Multiplex Communication Line (MPX-)
19 - Fuel Level Sending Unit Signal (FR)
20 - Steering Wheel Display Switch Input (MSSL)
21 - Illumination Dimmer Rheostat Variable Voltage Input (TR)
23 - Power Supply from DOME Fuse (B)
24 - Power Supply from MPX-B Fuse (B)
J35:
3 - Passenger Seat Belt Warning Light Signal Output (PBLT)
4 - Passenger Seat Belt Switch Signal Input (P/SB)
5 - Left Satellite Switch Input (RSEL)
6 - Right Satellite Switch Input (LSEL)
7 - SET Satellite Switch Input (SET)
9 - Illumination Ground-Side Dimmed Signal Output (ILL-)
10 - RH Turn Signal Indicator Input (B)
12 - Check Engine Light Signal Input (EFI)
15 - Brake Fluid Level Switch Input (SW)
  • 3 years later...
What irritates me is the differences in positions of my wires of my connection plugs. Maybe also the colors differ, but I don't find any XE20 wiring diagrams. Can we anyhow confirm what's wrong or right? I'd love to see wiring diagrams from 2ng gen IS without being forced to login on websites where I have to purchase any?
As for me, I want to run a 2nd gen cluster in my 1st gen Altezza.
Thanks in advance
