So fed up with my squeaky noisy Bosch blades and having to do more long runs in the rain I decided to buy some cheap eBay wipers (as you do) instead of the more expensive and noisy Bosch ones - so, go onto eBay and select a pair that according to their listings "will fit my car" of course I dont look at my own wipers until I go to fit and while they are in deed I suppose the "hook" type they seem wider and I cant seem to fit these as while they seem to click in ok the little plastic shroud wont close (see photo) I dont know if its needed to be honest but dont fancy just leaving them on in case they come off and scratch the screen - anyone any links to cheap not squeaky wipers that fit - or do I need to go back to Halfords and just get the cheap ones from there again.
If you go to ECP website you can still get Denso blades at 50%.
Cheers - order placed - previous code was invalid but there was a new code (at time of posting) MID80 so just under 50% off at £18 so still good
On my previous set I just modified the cover with a scalpel.
They worked, but i now have the Densos and they are SOOOOOOO much better than the Bosch Aeros that they replaced.
Denso's anytime,got the hybrid ones👌👍
Arrived and fitted - and it has not rained since 🤣
