'ABS' light on dash I reckon!
quite had to diagnose a problem when you have to work out what the problem is in the first place!
we are 'good' but not that good!
My first port of call would be looking to see if the wiring into one of the sensors is looking a little 'dodgy', especially as the fault comes and goes.
Slight possibility that the sensor is sort of damaged, but your Battery is one its way out, and the sensor is complaining ahead of fully failing (This to me seems less likely - unless you have other battery-about-to-go symptoms).
Does the ABS actually work (with light off and/or light on), might provide a diagnosis clue.
