Well having had the alternator fixed,now, apart from the drivers, all other electric windows are non-functional.  Looked to see if there was an obvious fuse and the sunroof is working.
Any ideas please??  Mark.
If the Battery has been disconnected or discharged the windows will need resetting. They will not work from the drivers door only from there own switches. Open the window to about half way then close keeping the switch operated for about five seconds after the window is closed. The windows should then work from the drivers door.
John.
Many thanks John.  I did know about re-setting but stupidly tried it from the drivers door controls!  Happy New Year....Mark.
