Hello i have a tuned is200 that i use as a winter car and i span out and hit a stone on the side of the road so my right back wheel got alot of toe in but i fixed that and now the abs light is on nonstop and the handbrake and the (traction controll off) light is flicking like crazy.
anyone know what the problem can be?
Depending what you needed to do to fix the suspension, you may have damaged the sensor on that wheel/corner. Easily done when disconnecting suspension arms and accidentally putting some strain on the wiring.
Sent from my Iphone using Tapatalk Pro
