Saw my hybrid Battery was full today. First time I've seen it full since I bought the car back in August. Is this a rare event? 🤣
Saw my hybrid battery was full today. First time I've seen it full since I bought the car back in August. Is this a rare event? [emoji1787]
Depends on how you drive it and how many miles you do freewheeling.
Mine is daily, but don’t let that worry you, I go down some pretty long hills and cover 250+ miles a day
I live near a long steep hill and even using engine braking the hybrid Battery tops out at 100% every time.
the 100% will be normal for you due to the long steep hill you go down
but normal driving you only get to approx 80% charge
The thing to bear in mind is that the bar display is not a Battery 100% or 0% display,  and the bars are not a linear as far as percentage charge for each individual bar. Zero bars is Battery at 40% charged. All green bars "or all full bars" is Battery 80% charged. These are the minimum and maximum charge levels the computer will allow  so you only ever get to use 40% of the potential Battery capacity.
John.
