Got a problem on another Is 200 it opens with the remote on the key but the key does not fit the door lock or boot lock and now the Battery has gone flat on car so key fob don’t work so  now I’m trying to work out how to get in to car can’t lift bonnet to put jump leads on  any ideas
3 hours ago, LeoLex said:
Change the battery in the fob?
How is that going to help the cars 12 volt Battery being flat, and not being able to operate the door solenoids or even receive the signal from the fob?
John.
You areright that’s why I never reply to it. If he had read my post like you clearly did he would never of posted such a reply. The best reply Iv had is to conext up to starter motor wire and that should put power in Battery to open boors Good way I think
Oh, sorry I miss read the original message.
I'm going to the dealership in  while to pick my vechs and will ask there and get back to you mate
The most common way people gain entry to the cars in this situation is to smash the small triangle window in the rear door and reach through and unlock the rear door. Personally I don't like this method, any smashing of windows is out the question for me. But just another way to gain entry. Either that or power to starter motor.
I hear that, a wasted expense really. What about if the key opens the boot and get a child to climb through the armrest in the back seat?
As said befor key only fits  ignition  Not door lock or boot lock. Going to conext Battery to starter motor and that will put power in car for key fob to work so problem solved So thank you for all the good  advice much appreciated
