Car started juddering while driving and idling, Eml flashed for a while..
Could it be spark plugs? Fuel? Its very undrivable from all the jerking
Help needed 😞
Why is it never something simple..
I see the number 2 coil has been changed before, i also had a loose injector connector
Not sure what to do here, check the plugs?
I can feel the misfire at idle, im going to check the spark plugs in the morning.. Ive a feeling they could be bad as there is no history of them being changed and its at 135k
Is there a way to check the coils, if i pull one out should i be seeing a spark?
Wish i knew more about this sort of thing...
So...
I have bought new spark plugs to see if it will cure the problem as they needed changed anyway just waiting for them to arrive, i have already taken the old ones out and they are fairly knackered looking.. at 135k there is no history of them being changed..
But i did clean the old spark plugs, made sure all connectors are in tight and reset the fault codes and its running 90% better (no more breaking up while driving, just a small misfire while idling) so hopefully the new plugs in will help
EML back on today, running rough again although one of the cylinders decided to stop misfiring.
Im hoping its just the plugs, i should really get that 02 sensor changed at some stage too
