Premier trim comes with xenon lights?
007M
Hi I'm considering getting a CT next year and would like to know a few things.
As per question, does all premier trim comes with Xenon headlights, if so does it have auto levelling and headlight washers? What is the wattage of the ballast?
Reversing camera and sensor all standard?
I assume for those trim that doesn't come with Xenon, there is no auto levelling and washers in place to retrofit hid later?
I should add I'm looking at year 2014 as I have read from then the suspension is not as bad and also just about what I can afford.
TIA
I believe that the premier trim has LED low beams and that lesser models have HID/xenon low beams. All have halogen high beams.
If you look at a premier model, the indicators are positioned on the inside of the lights, closer to the grille. On other models, the indicators are on the outside.
19 hours ago, stormchaser said:
Mines an SE L Premier and has all you state.
Sent from my iPhone using Tapatalk
What is the power of the Xenon ballast for your car if u know.
On 10/26/2019 at 7:01 PM, stormchaser said:
Sorry I don’t know.
Since your car has Xenon, therefore it will have auto levelling and washer. Does it still have the levelling dial in the car?
Thanks.
Been looking online for the CT premier, still cost a bit for a 2014 model, even the 2012- 2013 cost a bit too. Looking to trade in my Yaris hybrid so have to do so at car garages and they command a high price.
