Anyone fitted mudflaps to their NX 2018 on? How easy?
There's a little gap of paint behind each wheel that's not protected by plastic and they're worrying me.... 😳
Should be easy as access is excellent.
the kit will come with instructions.
Tel
Fitted them when I had a 2016 NX, easy enough to do. Turn the front wheels to full lock to give you clearance for the screws and clips. For the rears, it easier to jack the car up a bit to give you more space. You’ll need a small dump screwdriver if I remember correctly.
17 hours ago, C Mclean said:
Fitted them when I had a 2016 NX, easy enough to do. Turn the front wheels to full lock to give you clearance for the screws and clips. For the rears, it easier to Jack the car up a bit to give you more space. You’ll need a small dump screwdriver if I remember correctly.
Just noticed, it’s a “dumpy” screwdriver, not one you have passed thru your system....
Well, that's a relief! 😨
