Unable to read data. Check if the map DVD is correct,  bought new dvd, same error message, guessing issue is with the reader itself, not sure how to go about it., Any idea? sometimes the map will start working for and once I turn off engine, it goes back to unable to read data.
Have you tried a CD/DVD lens cleaner if it is still showing fault with a new disc, gotta be cheapest 1st option.
The next ( no cost! ) thing I would do is a 'soft reset' of the car ie disconnect the Battery negative connection for at least 15-20 minutes for all the non-volitile memory IC's in the car to draw down and start from default conditions.
Note. You will/may have to re-set electric Windows/Sunroof system but this is easily done but the ICE does not have any passcode security requirements unlike other manufacturers.
paul m.
Have you tried a normal music CD - it wont work but if you think the heads are not working on the reader you will either hear them thrashing about trying to read the CD or not which will prove the reader is both spinning and trying to read the disc.
Strangely the map started working last night, I've noticed it sometimes work when its cold and rainy outside, not sure if that mean anything but these days, whenever it works, it's always raining. Ejected it like 3 times and it started working again. Will check again today before the soft reset.
