Hi I have a 2006 is220d with a low Battery. I've had it jump started one but now it's drained so that I can't use the keyfob to unlock the vehicle.
The problem is that the alarm still works and I can't switch it off.
If I order a new Battery what's the best way of dealing with this situation without damaging anything, going deaf or having a constant alarm going off.
Thank you!
James
Hi NemesisUK,
Yes......I've just found out. When I disconnect the Battery there is a lower volume alarm coming from the rear.
There must be a back up? in the rear?
Guess what? The fob doesn't work so I can't open the boot(!)
Any clues?
I'm ordering a new Battery tonight but it would be nice to work on the car without going deaf.
