Memory Saver When Changing A New AGM Battery
KWCT200h
You'll always lose things like radio presets, nav settings and probably window/sunroof stuff to if you don't have an alternative 12V supply when you disconnect the Battery.
Rather than a memory saver that can't be used for anything else, I'd go for a jump start battery pack like these here that are multi-purpose devices and can even get you or someone else out of the doo-doo in the event of a flat Battery.
The engine, and hybrid transmission ECU will be re-set, and will automatically learn your driving style over the next few miles.
The windows will have to be re-set manually as will the sun roof "if fitted". The windows just need to be opened to about half way and then closed holding the switch in the closed position for about 5 seconds. That is all that there is to it.
You "may" loose any radio preset stations.
John.
if you do use an external power supply to keep your settings
remember when you have disconnected the Battery cables
the + red cable will still be live so dont let it touch the body
of the car.
when i removed my flat Battery to charge it
i hooked up a spare Battery under the bonnet using the jump starting tab
in the fusebox, i then removed the Battery cables and placed the + red cable
into a thick glove with a cable tie around it to stop it from coming off
this made sure it couldn't come in contact with the body.
2 hours ago, KWCT200h said:
Old battery was successfully replaced.
Thank you all.
Hope you got it from Lexus, the rest are adding big margins on because it's a Lexus. Some online were charging over double the Lexus price when I got mine
