A couple of questions
I have a couple of questions please.
Should the petrol cap access cover be locked when the car is locked, mine isn't and I can't find anything on it in the handbook.
The light in the drivers side sun visor is not working, is this likely to be a bulb/LED or a fuse.  The passenger side one is working fine when you expose the mirror.  I would have thought that it is more likely to be a bulb/LED as both sides would be on the same fuse.............wouldn't they?  Again, can't find anything in the book.
Many thanks.
Sorted!  It would appear that I didn't close the cover properly when I filled up with petrol and, when I locked the car 'it' remained unlocked and slightly open which I only noticed the following morning.  when I unlocked the car, then closed 'it' properly and then locked the car again, 'it' was properly locked.  Sheer stupidity on my part that🤔
As regards the visor light, Lexus tell me that it is covered under warranty and so I'll let them deal with it.
