Ok, so I got the car back and it drives ok for the most part. Gear changes are smooth, only occasionally the car would make a noise as if I drove over white line on a motorway and the vibration shakes the car a bit. It does it when it's in gear, so I'm not sure if this is because of the transmission or unrelated issue. My wild guess is this might be to do with solenoids being damaged and and not timing things correctly, but I might be wrong.
