Dear Lexus owners,
Do you know an independent Lexus specialist in Surrey or West London for front suspension work (  front wishbone bushes starting to perish ) Lexus Twickenham quoted £1,600 for replacement and the two new arms are around £300. I think a good local Independent garage would be able to do it for much less I hope. This recommendation work come as an advisory on the last MOT. There is no noise or any problems with the front suspension, but if the rubber is cracked it needs to get replaced. Any suggestions would be highly appreciated. Thank you in advance
I did the replacement on my previous 400h myself after looking into the workshop manual and finding that Lexus say remove the engine and transmission as the very first step. It was not easy and required the engine jacking up once the mounting was loosened and also the subframe dropping to the last few threads on the bolts to get enough clearance to remove the engine mount. Not an easy job.
I wouldn't rush into this job if I were you ,a bush can look perished on the exposed rubber part if there is no movement in the bush  it is as they say a advisory the rubber internally is ok I had a Ford Focus and for 5 years running your suspension wishbone rubber mounts are perishing but no movement etc .its a ploy most of the time to get you to do work that's not needed for a long time . Would they replace them if it was under warranty I think you would fine we will monitor it on the service sir .
  • 2 months later...
Any recommendations for an independent in Surrey (or Sussex etc)?
My 07 Rx400 is approaching 150k miles and the suspension is toast, no way I'm paying main dealer prices 🤪 There was a really good guy in Sidcup who did my timing belt years ago but he's not on my way to work anymore, so bit awkward to get to him...
Edit: aha, just found this guy - anyone ever heard/used them?
Thanks - I searched for other things but didn't think to use the garage name 😳
