Now that I have my air suspension working I’ve moved onto the air conditioning.
Can anyone tell me where the ECU, the fuse and I assume it has a solenoid?
At the moment the pump solenoid doesn’t engage, so I’m going to diagnose where the fault is.
I have a workshop manual for the RX300 if you want it.
Hi Herbie.
For some reason I didn’t get a notification that you posted.
I’ve since found out the car has a self diagnostic page. It’s reporting low pressure, which it isn’t, so I’ve ordered a pressure sensor
There’s no solenoid or fuse. Apparently. Still think there should be.
