Hi guys, been a while since I posted some news on here but it appears the IS will be coming late 2020/21
Current information is quite sparse but it will remain RWD and on the LNGA platform shared with the Toyota Crown so expect a longer wheelbase and length with width to remain the same. Now the main thing here is, it's going to be roughly between the current IS and outgoing GS in terms of overall length and is designed to fill the void of the GS (generally just means less production cost having one model in the lineup opposed to two)
Engines will remain the same i.e 200t (remains to be seen whether UK will get it) and the IS300h. Some sources are saying the 3.5l V6 will get changed to a 2.4l 4 cylinder turbo with improved power and torque i.e. circa 350hp but this isn't confirmed yet. However, Toyota sells the Crown with the 3.5l V6 hybrid as its top of the range model with the multistage transmission from the LC500 already. This could be seen too and would probably be the most logical solution.
Some good news for F fans, Lexus will return with the IS-F. Powertrain remains unknown. Some sources say 3.5l TTV6 with 416hp but I remain skeptical. I'd assume they'd want atleast 450hp to even remotely compete in the market. However, having said that, we all know Lexus doesn't play the horsepower top trumps game.
