I have a problem with the above item, I need to remove it as some dust or what ever is coming out ,what I need to know is how do I remove the vent without damaging it -- any ideas will help Sam Case
never had mine taken to pieces BUT maybe if you hard blow it all back into the vent would it ( the muck ) pop out the other side maybe ?
the vent is held in situ by enclosure pressure ,you need a plastic pry tool and just tease out the vent.
Don't be cheap and use a screwdriver. If you are messing about with the interior buy one of the plastic pry sets referred to above. Save that lovely soft touch interior.
