Now it’s getting warmer anybody noticed a buzzy type noise from the dash area on course surface roads (not bumpy) you can make it happen by putting the palm of hand under the dash overhang, the source of the noise is below the starter button and around the corner where the soft bit goes over the hard plastic.. I pushed a pice of felt about 3mm wide from the button around the corner up to the end of the soft bit of the dash. Pressed in with a credit card and soaked the felt in WD40. Job done. Hope it helps someone.
Use Silicon not WD 40 to lube plastics.
Tel
