Hi Just got the Samsung Galaxy S10 and it connects with in car phone system but when I try and transfer the contacts it displays error transfer unsuccessful anyone else having this problem, I suspect that my new phone has a newer version of Bluetooth software!
My wife had a similar issue when she recently got a Toyota Yaris.
On your phone, go to Bluetooth settings and look for your cars connection entry, theres a "Gear" symbol next to it, tap that.
Now you should see a list of what options are available ie Phone Calls, Media Audio etc
You need to enable Contact Sharing, some devices may then get you to re-pair as they have enabled a different connection protocol which wasn't standard.
Vince
Thank you I did that and click contact sharing and it unclicks it!
I have now sorted this, I had to change some settings on my phone and then select all contacts and share via Bluetooth and it worked!
