Hi, can anyone advise where I can get exactly the same paint as in the picture to respray both panels in IS300H?
I have tried and didn’t have much luck, so I ended up getting mine wrapped in gloss black, I’ll post some pics when I get in the car
A local auto paint factor would probably be able to assist.
I had an Audi in 'Kingfisher Blue'. The Audi dealer couldn't supply a touch up so I went to a local paint supplier who when checking the code found that in Germany it was Pelikan blue. This was why it wasn't listed at Audi UK🤔
This would be interesting to see
Did you use a heat gun? I have a few panels which I want to wrap them and not sure if I should get a heat gun. Didn't wrap anything in my life.
No, I used a hair dryer as I found a hot air gun to be a little too savage.
I wonder if the quality/thickness of the wrap plays a part in it, mine was bought from a vinyl supplier but was the cheaper end of the market
here are 2 images of a dash panel i wrapped in my partners Auris,
just be patient and use some heat when its needed.
