What info can be obtained from the Diagnostic Port mounted on the top of a 1995 (UK registered) LS400 engine?
What equipment do I need to access the information?
Was a OBD type socket factory fitted to the 1995 LS400?
What Ohmic value should a healthy Camshaft Position Sensor measure?
Can anyone help me to source ECU wiring connection diagrams for this specific 1995 model?
Apologies for the number of questions but I need to find/fix a problem.
Thanks,
Gulp .  sorry I have no idea ...  being one of the very few Mk3 owners here sadly
With there being a cam sensor on both cam gears you could measure both to see if they are the same value. If you do have a cam sensor fault it is quite common to find the wiring loom to the passenger side one damaged if it hasn’t been redressed correctly after a belt change....it can get chewed up by the serpentine belt.
Not too sure about the later model but earlier versions used a paperclip to read the codes by blinking lights sequences.
Also welcome to the LOC.
