Hi just purchased a 2007 RX350 and the navigation is version 2
What is the best way to update the navigation system as reading up on it, it is by dvd which is located in the boot.
So which way is the cheapest way to update it and what is the most recent version for my model
A simple eBay search should lead you the right way ^^ And regarding the update process it's as easy as changing the dvd, done!
Thanks for your reply.  Do you need to get a specific dvd for the RX or would anyone for a Lexus do
The seller should be able to confirm compatibility with yr car.  I bought a new disc for my 2006 rx400h on eBay last year.  They come in sets of about 4 discs which each cover different regions in Europe.   Some sellers must split the sets and sell the discs individually.   I bought only the one disc which I i wanted and it wasnt very expensive.
The best thing you can do is to take your current dvd out, snap a photo of it and simply find a newer version of that disc on eBay 🙂
No, the best thing you can do is to just leave the factory satnav as a rolling screensaver because it's old, clunky, counter-intuitive and just awful and use a standalone satnav or Waze on your smartphone instead :laughing:
Bought one from a website.
£19 I think ...
Worked well.
Brought one from eBay which is 2017-2018 update, should be down in the next couple of days and will post here to confirm it works, only cost £19
Just received the dvd update disc through the post.  To install it, it has a note that I need to eject old dvd, disconnect Battery for 15 to 20 mins and then connect Battery and load new dvd.  Does this sound right and when you disconnect the Battery does this not do something to the windows and also will I need a radio code.
6 hours ago, shivadread said:
Just received the dvd update disc through the post.  To install it, it has a note that I need to eject old dvd, disconnect battery for 15 to 20 mins and then connect battery and load new dvd.  Does this sound right and when you disconnect the battery does this not do something to the windows and also will I need a radio code.
I just swapped the DVD.
Think I had to have the ignition on, but never disconnected the Battery...
Biggest problems with using a smartphone or tablet are:
1) getting a GPS signal
2) finding a way to mount the device to the screen or dash.  How do you do it?
Have a look at my posting in this topic here - I think it's post No. 5 if I remember right:
