Replacing drivers seat belt,have to remove cover behind drivers seat which contains a speaker.Any help would be appreciated.
Thank looks complicated will try at the weekend
It's not so difficult but does take a while to work out where all of the fixings are. Skip to 15 minutes in and there are some pictures that will help you or jump to the end and it's obvious where the big thread is with more detail. There's also a mini version of it in the LOC project section here. Good luck.
Posted (edited)
Was going to post up pics but neil’s vid basically covers it all 👍🏻
Edited by mr2lad
On 5/23/2019 at 3:00 PM, Connoisseur said:
The US site is your friend. Try this thread to start with...
https://www.clublexus.com/forums/sc430-2nd-gen-2001-2010/420790-replacing-a-seat-belt.html
hth
Very informative,replaced old seat belt fitted perfectly only problem is old belt has an electrical connection,new belt does not.🤔
This is why i just got the seat belt webbing changed due to the electrics...it’ll be for the pretensioner system
i changed from beige to red belts
