9 hours ago, Casa1862 said:
You’re not buying a brand new car, all used cars will have a degree of wear, I think insisting they are changed at 33k is a bit demanding.
If the discs are lipped I always demand the pads / discs are replaced. Its the minimum you should expect from a Lexus main dealer. They would be quick enough to tell you they were worn when you rocked up at the next service and put that little seed of doubt in your mind 😉
By the way 30k was always a decent indicator for disc / pad replacement in the past. (obviously not in the case of Hybrids as mentioned above) .
If they refuse and claim its within tolerance or some other BS I walk. That's their loss. It doesn't mean the car is unsafe but if I was doing 15/ 20K a year I wouldn't expect to change anything within 12 months, tyres included if buying from a main dealer.
