I have a new CT200 only done about 1200 miles.
When I put my foot on the brake at low speeds it clicks
quite loudly any ideas
I have this on my MY17 CT. Only just noticed it before your post. I think it might be the regen system being activated as the brake pedal only needs to the pressed lightly. The car is booked in for it 2 year old service at Cambridge so will ask about it then and report back.
This was a common issue with the Gen3 Prius, the pad retaining clips would lose their spring tension over time and move in the calliper. not dangerous, just irritating.
When you have your pads done just change the retaining clips, that should stop it
I have a possibly similar noise on my 2018 CT, currently on 8k miles.  It's like a light cracking noise when braking at very low speeds.
I've read some worrying stuff about similar noises being knackered driveshafts (!) on Prius Gen 3 models, but also about the brake retainer mentioned above.
As mentioned in previous post had car looked at as part of service. Dealer thinks it could be steering column and best to monitor it?
More likely problem with brakes I think.
